HuckFinn410's avatar
HuckFinn410
Help. Under carriage plastic flapping. How to seal?
The large black plastic that covers the insulated undercarriage of my TT constantly comes unhooked and begins to “flap” or hang down. It used to be one long contiguous piece and was screwed in at the corners to hold it in. At some point, I had some work done on the black tank pipes and the repairman cut an approx. 5’x5’ piece to access the area. It was sealed back up with “100 mph” tape and that held for a little while. Ever since, I have struggled to find a way to get it to stay sealed. It doesn’t take long for it to start hanging down toward the road.
I’ve tried gorilla tape, “100 mph” tape and neither seems to work for very long. Does anyone have any suggestions on how I can get this sealed up for good. It is thick black plastic, butting up against the same thick black plastic.
Rivets? Some kind of NASCAR tape? “200 mph” tape? (not that I can get going quite that fast in my 5.3 v-8…..
Any Suggestions?
Sorry that I don’t have pics.
Thank you
  • One possibility would be to take a 2 inch wide piece of aluminum strip. Cut it to length, and then pop-rivet every few inches on both sides of the cut.
  • We have used the gorilla tape to seal ours for several years with no more flapping. Clean the area well with alcohol, allow to dry well and then tape.
  • Lilliemae30 wrote:
    How about that flex seal (black) spray you see advertised on TV? or maybe Rhino seal?
    That would work to seal up the crack, but I need something strong enough to hold the weight of the black plastic section.
  • How about that flex seal (black) spray you see advertised on TV? or maybe Rhino seal?
Looking for advice before your next adventure? Look no further.25,150 PostsLatest Activity: Jul 22, 2025
