Terryallan
May 27, 2013Explorer II
shawnw15 wrote:
Here are the numbers I found:
Hitch coupler height = 23 3/4
Truck alone:
Front height = 36 1/4
Rear height = 39 3/8
Truck with WDH attached:
Rear height = 38
From this measurement. It appears you have it right. You have the front back to where it was unloaded, and a 1" drop on the rear. That's pretty good. I believe thats about as good as it gets. You don't want the rear to be higher than it was unhooked.
As to your handling. Do you have the TV tires aired up? and the TT tires as well. Tires make a huge difference.
And do you have enough tongue weight? With the correct tongue weight, and your measurements you should have no sway.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
