shawnw15
May 27, 2013Explorer
TomG2 wrote:
Are the Timbrens compressed when hitched and WD applied? If they are not touching, you are still only using the stock suspension which you have judged to be inadequate. Timbren will supply spacers to take up any gap that exists. There "should" be a gap when unhitched to maintain the original ride. There should not be when towing. I had to play around with both spacers and hitch settings to get things right. Hope I haven't confused you. Mine had very little gap when unhitched, due to the weight of a fiberglass topper and the usual stuff in the bed of the truck.
Thank you for the reply, the timbrens are not compressed when WD is applied. I feel as if the Timbrens are not doing anything at this point with my WD applied. I will contact Timbren regarding the spacers and any advice. Thank you for the response, I hope the spacers solve my issue.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
