goducks10
May 28, 2013Explorer
I did something similar with a different truck, used air bags instead of Timbrens. Carried a lot of stuff in the truck and 1000lb bars were needed to set everything up, but they rode stiff. Dropped to 4-600 bars and the added the bags and it was great. Your Timbrens won't do anything with the WD setup, but if your adding another 4-600lbs for your ATV then they should come in to contact with the axle and help with stability. Your going to want them compressed pretty good cause if they are just touching the axle your going to get a rough ride with bumps in the road.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
