fsds123
Mar 06, 2016Explorer
Help with adding Dual Cam
I bought a used trailer that came with a draw-tite weight dist hitch. Am trying to add Reese Dual cam sway control to it. I have the hitch at the highest level on the shank, and the ball is at the same height as the trailer when not hooked up. Doing some preliminary measurements to mount the cams, I notice there is no pressure on the bars with 5 links. I can even lift the bars up another inch or so off the cams. Is it just a matter of getting a taller shank, and angling the hitch down some more with extra washers? Or is this hitch just not going to work with dual cams?
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
