Markiemark32
Mar 06, 2015Explorer
When dewinterinzing with anti-freeze, the process is to drain hot water heater, and THERE IS BY-PASS VALUES TO SHUT WATER OFF TO WATER HEATER, so you don't have to use lots of anti-freeze in the water heater, just anti-freezemain lines.
The by-pass values are turned off, if you are getting no hot water, (do not turn hot water heater on, with no water).
On my Sunseeker, NOT YOUR MODEL, they are actually accessed from under the bed, lines leading to the water heater.
A good resource is the Sunseeker forum:
FROG - Forest River Owners Group
Markiemark:C
Markiemark:C
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
