consumeratlarge
Mar 24, 2015Explorer
Thanks for those replies. I can visualize the pan turning the opposite direction at first, because of the tail swing. Then, in a constant radius turn, it seems like the pan's angle would have to turn the same angle as a car's wheels in the same radius turn. I understand the pivot at the hitch, but if you pulled the loaded dolly around a turn (if somebody was strong enough) doesn't it seem like the swiveling angle would limit the amount of turn? Since I've hit the stops for sure, what is 'giving' that allowed those turns to be made? I'd like to understand the physics to see where the stress goes.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
