mattinga's avatar
mattinga
Here's what I learned on the scales today
Went to the CAT scale this morning and learned a few things:
- My travel trailer is lighter than I thought when loaded with everything but full water tank. I've never towed this one with water because I was afraid of the weight
- My truck is not as close to the max weight as I thought
- I may need to tweak my Equal-i-zer Hitch more
Now I need your help:
I did two separate weighs - one with trailer hooked up and weight distributed, and one without trailer hooked up, but on the third section of the CAT scale. After getting home and looking everything over, I realize I should have added a third weigh and taken of the W/D bars to find the full tongue weight. Darn!
Here's the results:
Per door stickers: 2013 Silverado: Front & Rear Axle GVWR 3,950 each for GVWR of 7,000. Owners manual says GCWR is 15,000, with a max trailer weight of 9,500 pounds with my configuration (side note: why is the GCWR not 16,500?)
2010 Jayco 25BHS side sticker: 6,050 dry weight, 8,180 GVWR.
1st weight - trailer hooked up, truck loaded with everything (including two 90# dogs) but the wife, weight distribution applied:
Front Axle - 3,320, Rear Axle - 3,560, Trailer Axles - 5,640
2nd weight - trailer unhooked, on it's own section: Front axle - 3,500, Rear axle - 2,560, Trailer weight - 6,460
My instruction manual says to distribute 50% of the tongue weight. When I installed it last summer when I bought this camper, I did so by measuring front fender, and then setting WDH to return to half way mark between that and fully loaded. It rode like a dump truck at first, so I removed a washer to make it "feel" right on the road. I think I'm in-between washers - first it's too heavy on the front I thought, now I feel a little light on the front. I'd like to get as close to perfect as I can. Based on the weights above, I wonder if I should:
1) Move the L brackets up and try different washers to work the difference out
2) Add the washer back and add water to the fresh water tank, which sits forward the trailer axles and see how that does.
3rd option and better option?
Your thoughts? I felt like I would be just inside the limits of the truck when I traded our 184BH trailer for this one, particularly payload. It looks like I'm okay there based on the scale readings above. We're going on our first long trip in this camper in a few weeks, so I want to work the kinks out. We've only been on short trips so far, and it's been fine towing.
Thanks for your help.
Matt
  • It pulls pretty well, but sometimes I feel like it's a little light up front. No sway issues or anything (love that Equalizer hitch). Based soley on feel, I'd like to shift an little bit more weight to the front, but not all that the extra washer added.
    Not sure if this is useful or normal, but wet roads are not fun to drive on. It helps if I put the truck in 4wd high. My last camper was only 3,500 pounds GVWR, and it always towed great even in the rain. I certainly don't expect the same towing experience going from something that small to this bigger one, I'm just sure what's normal.
  • How does it pull?
    If it tows real solid then it's probably OK.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
