Atlee
Apr 16, 2014Explorer II
I used the Anderson hitch when I had my HiLo trailer. I liked it. It was simple to operate, simple to install. My biggest complaint was I had to undo the nut on each side each every time I hitched and unhitched. My other complaint was when I unhitched at an angle. If the angle was too large when I unhitched, it was hard to rehitch it latter, if I didn't back in at nearly the same angle.
I think you will like the way the Andersen Hitch works.
09KZMXT266 wrote:Ron3rd wrote:09KZMXT266 wrote:
Thanks all, but I went a different direction. I ordered an Andersen no-sway WDH. Very excited to get it and try it out. Thanks again for all the advice.
There's a growing number of Anderson users out there. Let us know how it works out for you once you set it up.
I'll do that. I'm sure it will do just fine if it's half as good as forum members and the online info I saw says it is. My toy hauler fully loaded really is only about 5000#. The hard part about my setup is how to deal with the tongue weight when my payload rating on the F150 FX4 is only 1199#. Having the TW take up most of that doesn't leave a lot of room for anything else. One of the things I like about the Andersen is it's less on the TW since it only weighs 55#. :)
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
