Bobbo
Sep 28, 2015Explorer III
I have the same system. My front tires are recommended at 65 psi, and my rear tires are recommended at 80 psi.
I use 58 psi as the lower limit for my front tires, 10% below 65 psi. I use 72 psi as the lower limit for my rear tires, 10% below the 80 psi.
Since all of the tires have the same sidewall rating, I use 100 psi for all of the tires as the upper limit. That is 20% above the 80 psi of the rear tires, rounded off.
I left the temp setting at the default 158 degrees F.
Coming home from our last camping trip, the TST actually alarmed high temp on the right front tire. It was showing 160 degrees. The right front brake was dragging and heating the wheel. When I stopped, it was smoking. Ford had to replace the right front brake caliper. I wish it had been under warranty, it was about $412.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
