Old-Biscuit
Sep 14, 2018Explorer III
YES it CAN cause issues.
The ACME Nuts on the pigtail hoses are different colors for visual indicators of flow ratings
Reason you have RED ACME Nuts is so they MATCH the flow capacity of the Regulator
(Black/100,000btu---Green/200,000btu---Red/400,000btu)
MEGR-253H ---350,000btu
OEM was a 200,000BTU Regulator/Green ACME which is more then the total propane flow of all your equipment.
With the HIGH FLOW MEGR Reg it will never be in its normal operating range EVEN if you had ALL Propane Appliances ON at same time.
That reg will always be 'pinched down' due to the lower btu demands
Will work...Yes
Will it cause issues....COULD because reg is always operating at low end of control range
There IS a reason behind the colors and the flow ratings ....just saying!
Will work...Yes
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
