Don___CarolynExplorerJul 06, 2013Higher temperature of tiresWe just purchased a tire pressure monitoring system that also reports the temperature. The two 5th wheel tires on the driver's side run about 10 - 15 degrees warmer than the two tires on the passenge...Show More
GaPeteExplorerJul 06, 2013Don & Carolyn wrote:Where do we find the heat rating for the tires? Bridgestone Duravis R250?Thanks!Look Here
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
Related ContentPSI when using higher load range tires.Intake manifold temperature creeping higherTire Temperaturestire and wheel temperaturesTire pressure and temperature recommendations
