Don___CarolynExplorerJul 06, 2013Higher temperature of tiresWe just purchased a tire pressure monitoring system that also reports the temperature. The two 5th wheel tires on the driver's side run about 10 - 15 degrees warmer than the two tires on the passenge...Show More
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: May 28, 2026
Related ContentPSI when using higher load range tires.Intake manifold temperature creeping higherTire TemperaturesTire pressure and temperature recommendationstire and wheel temperatures
