Campin_LI
Aug 06, 2013Explorer
TomG2 wrote:The point at which bolts fail was not the question I posted nor was it the basis for either reply above. However bolt tension comes into play as far as how tension is distributed on the bolts holding the receiver to the frame which was my question. If your post was not meant to be sarcastic, I apologize and as stated above by Berky, if the bolt is not in tension, it is loose, so the bolt has an initial tension due to tightening. Then you add the load from the hitch and/or WDH. This load adds more tension to these bolts. Then you have incidental and sometimes extreme loading from bouncing up the road adding more tension, but dampened by the suspension. If to much tension is added, the bolt breaks.
What if they are 1/2" Grade 8 bolts torqued to 140 foot pounds? And why do we care?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
