Mikesr
Jun 07, 2017Explorer
Hitch Advice
Recently took delivery on a Keystone Outback 325BH with a dry weight of 8400# and a hitch weight of 950# and is 37 feet long per manufacturer specs. TV is a 2005 Chevy Silverado 2500 HD 6.0 gas exten...
aftermath wrote:
Since you had an Equalizer before I would suggest you get the larger version. With the 1200 bars you should be fine. Your 900 or so pounds of HW is probably under stated. I really like mine and it remains easy to hook and unhook. I have also tweaked mine a few times to get it where I like it. Adding or removing washers is easy. Adjusting the L brackets is not difficult either and the directions from the company make sense and are easy to follow. I also like not having to snap those chains into place.
I also believe that you have plenty of truck to tow this trailer as large as it is.
