Recently took delivery on a Keystone Outback 325BH with a dry weight of 8400# and a hitch weight of 950# and is 37 feet long per manufacturer specs. TV is a 2005 Chevy Silverado 2500 HD 6.0 gas exten...
I pull a 38ft, 10,350lb TT with the blue of sway pro. I pulled it thru 35mph side wind and across mountain passes. Set the ball 24-26ish inches high from the ground and run link 9-10. That is link 9-10 in the bracket, not 10 links showing. The sway pro is a great hitch, there is no reason to spend the extra money on a "premium" hitch.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
