jesseannie's avatar
jesseannie
Hitch Failure UPDATE
A month or so ago we were towing our travel trailer and the weight distributions hitch failed. When that happened the entire weight of the trailer was on the hitch. When I looked at the situation the hitch looked damaged so we got AAA to tow the trailer home and stored it.
Today I had time to take the truck to an automotive shop that does a lot of fabrication and hitch work.
The hitch was not bent or damaged but the frame was deformed and the rear two bolts on the hitch were nearly separated from the frame.
The mechanic did not take long to diagnose the problem. The hitch that was installed by the RV dealership was not the correct one for my vehicle and furthermore it was installed improperly.
The solution: I ordered a new Curt hitch and a Curt trunnion flat bar weight distribution hitch.
The shop will repair the frame, reinforce it and install the new parts.
FYI the trailer tongue weight was well within the spec's for the hitch and the truck.
I am thankful we got everything home in one piece and am looking forward to getting our rig back on the road.
jesseannie
  • Sure the RV dealer "should" be paying, but that would be a long row to hoe, and cost more than just fixing the problem and getting on with life.
    I would like to see photos of the damage and the improperly installed hitch.
    Did the mechanic say how it was improperly installed? These days most hitches are no-drill, bolt-on affairs, especially when it comes to pickup trucks. Very difficult if not impossible to screw up.
  • schlep1967 wrote:
    I'm thinking at a minimum the RV Dealership would be paying for the frame repairs. And they would be getting off cheap with that as they should be paying for the damage and refunding everything you paid for the first hitch and the cost to install the first hitch. Plus the towing costs.
    I agree.
  • I'm thinking at a minimum the RV Dealership would be paying for the frame repairs. And they would be getting off cheap with that as they should be paying for the damage and refunding everything you paid for the first hitch and the cost to install the first hitch. Plus the towing costs.
  • Can you post some pictures of the damage so we can see what failed?
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
