I have a question about where the hitch pin goes into the receiver on my three-quarter ton 2009 Chevy pick up I've noticed it's starting to wear out .. maybe another way to put it where the hitch pi...
Using a WD hitch you'll need a 5/8" pin. How is the hole on the stinger for the ball? If it gets to bad You'll either have to replace the receiver or weld up the holes and redrill them.
To reweld & drill them I'd pull the receiver off the truck to do the work. It will be easier to clamp it to a drill press than to try drilling them with a hand drill.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Jan 02, 2026
