jokaj's avatar
jokaj
Hitch Rating Question
I have a new to me Class C with a hitch in the back. The hitch has a sticker rating for Trailers: Max gross trailer wt 3500 lbs, Max tongue wt 350 lbs. and Dinghy tow Max gross trailer wt 5000 lbs, Max tongue wt 100 lbs.
Usually tongue weight is ~10% of the max trailer weight but for the life of me, I don't know why towing a dinghy would be a tongue weight of 100 lbs. I was going to dolly tow my car using a dual hitch so I could bring my bikes.
Can anyone explain to me what's going on? Thanks!
Joe
  • jokaj wrote:
    Thanks for the response. My main concern is whether or not I can tow a dolly and have a bike hitch on the same hitch. The 100 lb tongue weight would essentially prevent me from carrying my bikes........
    can you get a bike rack for the toad?
  • Thanks for the response. My main concern is whether or not I can tow a dolly and have a bike hitch on the same hitch. The 100 lb tongue weight would essentially prevent me from carrying my bikes........
  • 4 down towing has nearly no tongue weight. The hitch is rated to tow a toad 4 down not exceeding 5000lbs.
    If your tow dolly will have less than 100 lbs of tongue weight with the car loaded, you should be good to go.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
