I currently have an ez lift load leveler system using two friction sway bars. I pull a travel trailer weighing close to 7000# and 30 feet long. I am not very satisfied with the sway bars as I still ge...
If the Husky Centerline is the Reese Dual Cam clone (Reese Straightline) it will be money well spent. I have used the Reese Dual Cam many years with excellent results. I do agree that you need to determine still why you have sway. A properly set up hitch will not sway under normal conditions. Your Titan needs E rated tires if it doesn't already have them.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
