Baja_Man's avatar
Baja_Man
Hitches-Equal-i-zer; Reese DC; Blue Ox-Diffs/Similarities?
I have reviewed these WD hitches and had a few questions to be sure I am correct in my thinking.
My TW is 1450# (dry). It is a Toyhauler so the 1450# is max and will be reduced when weight is added to rear of trailer axles. I will not added quads/motorcycles....but will carry bicycles, firewood, ice chests, etc. I have plenty of truck (F-350).
I believe all of these hitches do a great job at distributing weight and controlling sway. I understand there are differences and some have their preferences, as well as pros/cons.
I know some carry the bars low and this can be a concern.
Some
With that said:
1. Reese DC: This system requires drilling into trailer A frame. Are there optional frame brackets where drilling into frame is not required (ex. clamp/bolt-on)? I could not find this option anywhere; I assume it is not an option. Is it? This system does allow for head angle adjustment. (NOTE: Systems available for 1500# TW and 1700#TW).
2. Blue ox: How does chain, moving freely side to side as well as up and down, control sway and distribute weight with all of this chain movement? It seems that that rigid bars of the Equal-i-zer hitch solves this, correct? (NOTE: Systems available for 1500# TW or 2000# TW). Head unit has a fixed angle...how does it not need to be adjusted....isn't angle adjustment needed to add/reduce load on bars and distribute weight?
3. Equal-i-zer....This is what I have experience with on two different trailers. The hitch head has the ability to adjust its angle to add/reduce load on bars and distribute weight. It's noisy but with plastic pads noise has been reduced. Since my TW is at 1450# and Equal-i-zer system has a max rating of 1400#, should this be removed from my options? If so, why? Is 50# over a safety issue?
Thanks!
  • I don't know what the new equalizer hitches are like. I bought a new one, I think it was just after they came in to being around 1968. The spring bars were the old style with the chain hook up to either side of the trailer tongue. I have 5th wheel now & don't use it much anymore except for towing my utility trailer. If the new ones work anywhere near as well as mine you will never need another. It eliminates the need for any kind of anti sway device if set up right. Or mine does anyway. Used it to tow some very large and very heavy trailers. Never had a problem. For me noise was never a issue.
  • I have had all three....All three worked great.
    Equal-i-zer was just too noisy...screeching, popping....wife hated it.
    Dual Cam: Drilling for the snap up brackets was no big deal...Lots of adjustment and "dialing in" before it works correctly.
    Blue Ox: very easy to install. I have a 90 degree narrow back in to get our trailer into the driveway. Dual Cam didn't like this severe angle and actually worked best when I un-hooked it for this maneuver . Blue Ox doesn't mind the 90 degree turn angle at all. It is also very quiet.
    Again...all three did an excellent job of distributing the weight and controlling and sway.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
