mike243
Dec 19, 2013Explorer
Don't put any thing between the fridge & the door gasket as it can make the gasket take a set & not seal,also when you go back to using it the gaskets may not pull back up without using a hair dryer on them to let them stretch & catch .best thing to do is let it air dry for a week & then close the doors. Getting the moisture out will keep mold/mildew out. The icemaker needs to be drained . If you have a home style fridge & you live in cold climates & it has water/ice dispensers you may have stuff bust if no heat is left on in the unit or if antifreeze isn't in it,
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
