studies01's avatar
studies01
Holding tank odor...
My son's 2001 CC Allure has a persistent gray tank odor that permeates the coach interior within a few minutes of each departure. We have tried rinsing/washing/flooding/etc., the sink traps, washing machine trap/standpipe, shower trap and the black & gray holding tanks numerous times and are pretty sure that most, if not all debris, has been purged and all of the traps hold water. Yet the odor persists....
The plumbing on this coach looks in real good shape and probably rivals that found in an upscale home. There are four roof vents and we can detect the scent of bleach [which we used to identify which holding tank was causing the odor]in all of them. This would lead me to think there is a crossover vent between the black & gray tanks especially since we only put bleach into the gray tank. From what we can reach and/or inspect there appears to be no loose, cracked or broken pipes in the drain/vent system. There are also no [water] leaks under the MH either.
Any suggestions from our audience?
  • I got these 'tablet' deodorant things that you dissolve in the sink that goes to the grey tank. I put one of these down the drain after I dump.
    By the next time I need to dump with a full grey tank, it's not near as foul smelling as it was before...
    The first time I treated my tank this way, I filled the tank with about 10 gallons of water (30 gallon tank) before I left home. The guy at the RV store where I got the deodorizer suggested this to kinda 'stir up' the tank and it'll get rid of the crud build up on the walls of the tank and whatnot..
    That was a couple of years ago and my grey tank does not smell as bad as it did before, and the tank sensors actually work better too! :)
    Good luck!
    Mitch
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: May 12, 2025
