Lakejumper's avatar
Lakejumper
Home - Waste Dump
I’m having my sewer clean out moved out from underneath our home. I want to be able to dump the RV in it. What size line should we use, 3” or 4”?
  • Thanks for all of the quick responses. I’m connected to city sewer and already have a “y” connector under the house in the Crawlspace. We are extending the cleanout through a vent cover. We decided to use a 4” cap. I already have a Flojet macerator and also want to be able to use the 3” hose if needed. I think that we have it covered.
  • buy a macerator and just send it down the toilet. or a 2 inch line will work for the hose.
    I "sent it down the toilet" and smelled up the house. Never again.
  • If you have a septic tank, there should be a line in, a line out and a cleanout in the lid. You don't want to dump in that cleanout, instead you should have a tee in the line that goes in. I suspect that your "cleanout" is a Y on the pipe from the house to the septic tank and that would be fine for dumping as long as you maintain a capped Y for future clogging issues. For your dump line, 3" or 4" is fine, the most common size is 4".
    In my area they are pushing for installation of a manhole in the tank lid so it can be properly inspected. Yes, pumping and inspection is now required.
  • sewer clean-out access are almost always at least 6"...ours at home is. i have our line cleaned out annually to prevent nasty backups. the guys were here yesterday and used a 6" cutter.
  • I'm thinking the plumber would decide that but I think ours is at least four inches; probably more like 6.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
