lanerd
Apr 06, 2015Explorer II
The following is what Remco says for the model, eng, and trans I arbitrarily picked for a 2012 Accord:
2012 Honda Accord LX FWD I-4 2.4L cyl 5 Speed Automatic M91A/B90A
Notes
Towable as is with speed and/or distance restrictions. Please see Owner's Manual for confirmation and procedures.
It is not recommended to tow this vehicle over 65MPH
When towing for an extended period of time, start the vehicle as often as possible and allow it to run for five minutes to prevent battery drain.
Officially from both Honda and REMCO the vehicle is not towable. However, we at Remco have a large number of customers who are flat-towing that vehicle behind their Motor Home and they are not having any issues. Follow the "Emergency Towing" procedures in the owner's manual to a "T" except ignore the restrictions and follow those procedures each and every time you tow. NOTE: If you choose tow your Honda, and have any damage to the Transmission as a result, you will have to pay for that expense out of pocket. It is nothing that Honda or Remco will warranty. Also, it should be noted that Remco sells no aftermarket product (Lube Pump or otherwise) to make this car towable.
Notes
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
