golfknut
Sep 16, 2015Explorer
I chose not to cut into the car's wiring and used power from the motorhome to run the lights. I had new bulbs added to the rear light housing and then four wires run to them from the plug-in socket mounted to the front of the Fit.
You can see the four wire bunch in the first photo going around the right side of the battery.
Here is a photo of one of the light housings. Hopefully you can see the original bulb and then the newly installed bulb.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
