JBarca
Dec 30, 2013Nomad II
eldee wrote:
Brakes work VERY well when applied manually, seems this indicates system works, just not like it should.
Both settings are set to max, should almost lock brakes up, right? BTW, this is a Carri-Lite, weighs about 10,000 lbs or so, all 4 brakes recently adjusted. System has behaved like this since first installed over 2 years ago. Maybe I'm expecting too much, just feels like I have to use a pretty heavy pedal to slow down. Thanks again everyone, Larry
There is another thought and it just rang when you said you have been using this 2 years and you need a lot pedal push to slow down.
Here is the thought. The manual lever is a direct max power, does this controller by chance have an amps read out? If so what are the amps? both manual full squeeze and then by the foot?
The manual system gives it all she's got fast whether or not it is all getting to the wheels or not if still an unknown. The automatic mode takes a small bit of time as they know you do not want to lock up the brakes.
Where I am going with this is voltage drop in the wiring on the camper. I do not know about yours exactly, however many towable campers have very poor wire sizing and connections. Small wire and bad connections rob precious power from ever making it to the wheels.
See here were I upgraded my wiring, it makes a difference in stopping. I borrowed this from forum member Les Adams.
Independent Brake Wire Feed Upgrade
If you want to test if you are loosing power to the wheels you can try this. Do a voltage check at the truck 7 wire plug with a known amount of manual lever being depressed. What is that voltage? Then go to the farthest wheel that is wired as a place to start. Your going to have to figure out how to get your test lead right on the magnet coils wires. Ideally do several wheels and the same amount of manual lever?
Edit: Or do the truck voltage check under the dash where the controller power is entering the wiring harness to head out the back of the truck. That is the real source.
What is the difference in voltage from the truck 7 wire plug to the brake magnets? When you only have 12.7 to 13.7 volts to work with, losing a volt or 2 just getting to the wheels is going to make for sluggish braking. Now the controller has to work harder to put out excess power as your loosing a high percentage in high resistance wires or connections. The high resistance can act just as bad as a totally out of adjustment brake mechanical setting.
Just passing it along in case you need something to test where the problem might be.
Hope this helps and report back what you find. We too pick up learning's from you.
John
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
