cktrow11's avatar
cktrow11
Horrible Sway
I tried to find a previous post, but was unable to. Sorry if this is a common question/post.
I have a 2015 Hideout 31rbts. Dry weight is 8500# from the factory. I tow it with a 2011 Ford F250 6.7 Powerstroke and use a Husky weight distibution hitch with dual sway bars - all rated to handle it. When I pull it though, it sways horribly if I do over 50 MPH even with 2 sway bars tightened down. I haven't scaled it, but I believe I have our load evenly distributed. We are full timers for now while I move around with my job, so I don't pull often. When I do though it's long distances and makes it even longer having to do 50mph or less. I've only made 3 trips so far, but dread any future ones as the last one was a 3 day trip that never seemed to end.
Tonight I measured the trailer and the hitch to see if maybe the dealer didnt set up the hitch properly and the ball on the truck is actually 3" higher than the trailer measurement. Will being that high cause sway? Manufacturer directions say 1" higher. I'm going to lower it, but I don't leave this work spot until February so just trying to get some peace of mind between now and then.
Sorry for the long post, but thanks for any input. Just want to know if it's a setup issue, or if I should go trade off our brand new camper we thought would be so perfect.
  • Your tongue weight should be about 15% of your TT weight. The TT should be level when towed. 15% of 8500 should be about 1275 pounds. That of course changes when the TT is loaded. Very light tongue weight can cause sway. May be worth your while to get your TT weighed. When I towed TTs I bought a tongue scale. Well worth the price. Others will chime in but I think weighing is the next important step.
  • Get the ball down some, and add weight up front to the tongue. If all of that doesn't help get a used Hensley.
  • Have you tried to fill your fresh water tank to increase the tongue weight?
    -Bryan
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
