jdog
Mar 31, 2014Explorer
HOT AND COLD WATER HOSES
I had a leak at my outside shower. Every time I fix it, the leak starts again later on. I found out that Accuflex T2008 for COLD WATER was used on the Hot and Cold water lines. They were connected to pex hoses through T fittings. Not good when hot water runs through the cold water only flex tubing. This is what caused the leaks. Anyone else have this problem?
