wa8yxm
Apr 01, 2021Explorer III
machunt wrote:
Will the hot water heater light on Lp if no water in tank?
Well why would you want to heat HOT water?
Now to answer your question YES. and that's not a good thing
Same for the electric element it will come on without water.. Till it burns up.
IF your water heater is an ATWOOD or like there is a foam pad with the letters E.C.O. and T-Stat on it. Remove one of the RED wires from the E.C.O. when you drain the tank, Reattach after you refill the water heater...
What does this do.. Prevents you from saying OH CH!!!! I did not fill the tank.. (I've forgotten the wire. and Why the )!Q@#$R did the fault..... oH I forgot the wire.) But I remember to fill the tank when that happens.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
