joesann's avatar
joesann
Hot water tank draining
Just got our KZ Spree Travel Trailer ready for winter :( Forgot how to relieve the pressure on the hot water tank. Unscrewed the rod to drain the tank, and the extra pressure in the tank, I got a bath. How do you make it so there is less presure in the tank to prevent water from blasting out of the tank ?
  • I turn on the outside shower to the hot water faucet and let the water drain that way.
    chevman
  • -If used recently, allow water in tank to cool, after cooling
    -Make sure pump is turned Off
    -Open hot water faucet(s)
    -Flip cock of pressure relief valve at water heater
    -Unscrew anode rod (if part of your water heater)
    -Drain tank
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 24, 2025
