machunt's avatar
machunt
Hot water
Gotta ask. when everyone id using there RV, how many have really clody, milky hot water? if so what have you done to remedy this?
  • BarneyS wrote:
    Sounds to me exactly like anti freeze in the water heater tank. It takes forever to get that stuff out if you don't change the winterizing valves correctly when either winterizing or de-winterizing. It doesn't take much either, to make the water foamy for a long time.
    Barney
    This. Happened to me once because of my error. Took a long time to clean out the HW tank.
  • i've seen that on one RV a friend had
    something to do with the water where he lived
    setting in the heater in storage
    its been ten years and i don't remember the explanation
    whether it was chemical or bacterial, seem to think it was something to do with sulfur content, i do remember it smelled that way
  • machunt wrote:
    how do flush your hot water tank
    If a suburban pull the anode rod. If an attwood open the pressure relieve valve and let the water run a while.
  • Sounds to me exactly like anti freeze in the water heater tank. It takes forever to get that stuff out if you don't change the winterizing valves correctly when either winterizing or de-winterizing. It doesn't take much either, to make the water foamy for a long time.
    Barney
  • It is most likely very fine air bubbles. Fill a glass and let it settle. If it is clear and there is no sediment you have nothing to worry about.
  • sounds like your tank needs a good flushing out. most likely lime deposits built up in the tank.
