MrWizard
Oct 14, 2015Moderator
DutchmenSport wrote:
You're probably going to get some mixed responses here, I think its personal preference, really.
If you travel a lot, then you probably do not want electric only. If you are parked at a permanent site, then elecctric only is the way to go.
But one thing YOU do need to consider. You can run a 2 way, or 3 way refrigerator on Gas if you hooked up to electric or NOT. You can run the gas when traveling too. But if you have an electric only, and you are not hooked up to electric, your refrigerator won't work either. You'll probably find yourself using ice chests packed with ice and you'll wonder what good is that refrigerator for anyway.
where do you get that idea
if the MFG is building it with the residential fridge
most likely it comes with inverter and batteries to support it while in motion between locations and dry camping, and possibly a generator
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
