prier5's avatar
prier5
How cold is to cold
We have a 2006 keystone couger 32rls and are heading to the Reno area. The temps are ranging from the mid 20s at night to the mid 30s at night. Our rig has an enclosed underbelly but no heat there. I am worried that my tanks and or lines will freeze and break. Any advise or recommendations would be appreciated.
  • Besides burning a lot of propane you should be fine. If you have an outside shower, open the door and stuff some insulation in it, Leave any doors open that access water lines.
  • We've spent many nights in our older coach in temps as low as -4 deg F both in comfort and without any significant pipes freezing.
  • We have camped out in temperatures like you describe, no problem at all. Disconect the water line and drain it.
    My dealer told me to worry only if the temp drop 10 below freezing for more than three days. Haven't run into any frozen pipes yet.
    A lot of people here will strongly disagree. Your choice.
    Winter started here last October and it's still here, we know what cold is.
  • I had a look at Reno weather and the next two weeks might have only one or two degrees of freezing. If you are living in it while you are there.. you will be fine.
    The most sensitive spots are usually outside showers, and dump valves.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
