SoundGuy
Sep 16, 2016Explorer
rvhippo wrote:
What I don't understand is that one can send 40-50 psi of water or air through the valve during normal operation or winteriztion, but if I want to just release some trapped water, the valve can break so easily.
The check valve doesn't "break" ... rather excessive pressure causes the small rubber O ring inside to dislodge and the check valve can no longer seal properly. Simple solution - before pressing the check valve stem always relieve pressure in the system a bit by turning on one of your faucets for a few seconds, then close it again. There'll be sufficient pressure left in the system to push any unwanted water out of that city water inlet hose yet not enough to dislodge the O ring.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
