georgelesley
Sep 17, 2016Explorer
Terryallan wrote:DutchmenSport wrote:
I run "pink stuff" through the water lines via the on-board pump. Then use an air compressor attached to the fresh water city inlet and pump air to push the pink out and it all goes in the holding tanks then. Using air via the city water inlet will definitely get rid of any trapped water. (This works for me). The entire process still only takes about 15 minutes.
On my old TT I used pink stuff, However on the new one, because I can't get to the inlet side of the pump, I just use air thru the city water. Never thought about doing both? Why should I do pink, and air?
Theoretically blowing alone should do the job. I like to pump pink after blowing the lines. Blowing it will take care of the inlet check valve for sure
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
