EnzoColorado's avatar
EnzoColorado
Explorer II
Jul 27, 2023
How do I pop this cover off to replace the ceiling light
I tried to pry with a prying tool and it feel solidly in place. Tried to twist and it didn't turn either. Need to replace this ceiling LED light. Thanks.
Link to the photo of the light
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    EnzoColorado wrote:
    Got it off, turned out the inside lens pops off, then it's four screws to get the whole thing off, it's only screwed directly onto the ceiling, no box/hole or anything. Pretty cheap construction.
    Glad you got it off and that's standard practice for 12 volt lights.
    Check your marker/clearance lights
    or (Depending on the model year) The tail lights on a car or Trailer or Semi Truck.
  • Got it off, turned out the inside lens pops off, then it's four screws to get the whole thing off, it's only screwed directly onto the ceiling, no box/hole or anything. Pretty cheap construction.
  • Pull straight down on both sides of the trim ring.
  • If they are like mine they are held in place by a spring that is about rat trap strong.
  • wildtoad wrote:
    That looks like a standard can light. Have you tried pulling the decorative rim straight down using both hands?
    I tried with a prying tool to pull down and it budged a little but otherwise didn't come loose. I didn't want to break something.
  • OK, guess i should have read the entire post, i see you have tried twisting it.
  • I don't have that type, but have you tried to twist that outer ring, maybe it screws off/on, try counter clockwise.
  • That looks like a standard can light. Have you tried pulling the decorative rim straight down using both hands?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
