rav wrote:
never use chemicals. I drain the tank, use the built in flush, close valve and let fill up for about 8 to minutes (yes I use a timer) then dump, flush and then add about 5 gallons to the tank. We do have a water softener so that helps keep the tank "slick", sometimes I will put some laundry detergent in the tank.
Ditto. Sometimes use a little Dawn dishwashing liquid. Squirt before we head home and dump at our storage area. Very convenient. Slippery right out the tube. Zero stinky. We too use the restrooms for solids when possible so none or very little solids.
We use the anti-stink tabs. For us they worked great. Forgot one time and we could tell, not bad but wafty.
Early on, the 1/3 was always on even when the tank was empty. Filled with 5 gal of hot water, a drop or two of soap and drove 5 miles. No problem since.
To each their own. This is what works for us.
