ScottG wrote:
The brakes on the vehicle help stop the trailer and this is designed into the vehicle. That's why trucks have such huge brakes for their size. Notice the brakes on trucks have gotten bigger over the years? Not because the trucks themselves are that much heavier, it's because they can tow much more than they used to.
The more weight you add to a given setup, the longer the stopping distance.
I have upgraded brakes on my truck and it stops the whole 17K# load faster.
BTW, I have seen both Ford and GM write about this very subject and they make it clear that the trucks are part of the formula and have a major impact on stopping the trailer. So yes, it is clearly part of the certification or more accurately, it's part of the design criteria.
The big reason that trucks have large brakes for their size is that empty tow vehicles generally have a high power to weight ratio, enabling people to drive faster with or without a trailer. The faster you drive the more brakes you need. You may notice that most performance cars have big brakes even though they have zero rated tow capacity. The big brakes do help stop trailers as an added benefit but the problem with that is then your braking ability is limited to the traction that the truck has. As your trailer get heavier that becomes a bigger and bigger issue. To stop quickly you need every tire on the ground doing all it can to help. If your trailer axles are carrying twice as much weight as the truck axles are and the trailer brakes fail you are going to take at least 3 times farther to stop, no matter how good the truck brakes are. In this case, fade resistant truck brakes will help keep the distance from being more than 3 times as far.
In general, a 7K axle on a trailer does not need to be as large as the brakes on a 7k truck axle because you physically can't do repetitive stops as frequently due to the mass of the trailer slowing your acceleration. The brakes have longer to cool down during the slower acceleration and when you do use them the power produced by engine is split between more brakes.
Good trailer brakes also help prevent jacknife situations.
