SweetLou's avatar
SweetLou
How Fast For 12 Inch Tires
I have a small utility trailer that I just purchased. It has 4.80 x 12 tires. How fast can these wheels actually go with out burning up the bearings? I don’t need the “legal limit stuff” guys. Real information please.
  • I will tow it 1500 one way, then same back with a light load if this helps
  • 4.80 x 12 Load Range 'B'.......45 mph
    4.80 x 12 Load Range 'C'.......55 mph
    4.80 x 12 'High Speed'........62 mph
  • I'd be more concerned with the tires than the bearings. I see a lot more trailers with snowmachines on them that have flats and blowout problems than I see pulled over for bearing problems. On my larger trailers for 50 - 100 miles trips to go snowmachining I often leave without a spare, but I never leave without one on my small two place trailer.
    Bill
  • I have a 4'x8' utility trailer with the 12" wheels. I routinely tow it at 70 mph and have for years. I check the bearings and grease them every year.
    Before this one I had a same size trailer with 8" wheels. Towed it the same way for many years until a guy ran into the back of me and crunched it. Replaced the bearings after several years when one of them got a little worn, but not failed.
    Those little wheels scream at highway speeds but the hubs have never gotten close to being hot. I always feel them when I stop for any reason.
  • Weight has more to do with it than anything, other than the bearings not being packed well. FWIW I ran 4.80x8 tires on a MC trailer. Total weight was around 250lbs. I ran 70-75 all day. Tires were never hot, always cooler that the MC's tires. I packed my bearings my self so I knew they were good. Question is who made the trailer and how well the bearings are packed. If they are the cheapo china junk in there then I would replaced them with Timken's. Pack the crude out of them. And run 65-70 all day. If your loaded to the gills then maybe not.
  • Just keep bearings lubricated and don't overload or have improper air pressure in tires.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
