Grit_dog
Nov 02, 2020Trailblazer
Gdetrailer wrote:Grit dog wrote:
Small engines, guys, seriously check out Av gas.
It may actually be cheaper. If going through gas quickly, non of this matters. Use E10 all you want. No problem.
But stuff that may or does sit for months at a time, by the time you buy no ethanol, generally it’s premium. Very few stations with 87 no E gas. I know where a few are but even 87 no E is ‘spensive. Then you dump in stabilizer.
Add it up and you may have paid more than buying 100LL.
Here 91 no E is usually around $4 plus stabilizer. AV was $4.56 last week when I filled up.
:R
I have mentioned this before, MANY "airports" you cannot simply walk in and buy "AV" gas without a valid "Tailnumber", PERIOD.
HERE is a simular "discussion" on a different forum that I am not involved with that basically says the same thing.. They do list some possible ways around the tail number but in most airports you WILL find the fuel pumps out of the way AND LOCKED and you WILL need the airport manager to get access.
HERE is another discussion forum that says the same thing as the link above..
HERE is yet another discussion forum that says the same thing as above.. Not to mention this discussion talks about the possible need to rejet, may need to adjust timing to take advantage of the higher octane.. Not to mention, standard off the shelf small engines are low compression (8.x to 1) which means a lot of wasted energy in the higher octane fuel needlessly being sent right out the exhaust.
HERE is yet another AV gas in small engine discussion which mentions that the us of 100LL AV gas CAN cause small engines to RUN EXTREMELY HOTTER.. EXCESS HEAT can destroy your precious EXPENSIVE SMALL engine you are trying to "protect" from that nasty old Ethanol :R :E
There are plenty more examples as to why AV gas may not be easy to get or may not be a good idea to use if you let your fingers search the wobbly web..
Small engine carbs are dirt cheap compared to repowering a gen or lawnmower with a new or rebuilt engine.
Besides, 100LL is way overkill for any small engine and is stupid to spend $4 per gallon when you can use any old regular 87 (which IS what small engines are designed for) at $2 per gallon..
How?
DRAIN THE CARB, that's it.. Nothing special, no "AV gas", No "racing fuel", no magic potions, incantations, wizardry, no snake oil fixes.
In the spring, add fresh fuel to the tank and open the tank valve and let it rip. Been doing it this way for the last 30+ yrs with small engines with zero destroyed small engines or small engine carbs..
That is a push mower, two gens, two chainsaws, one weed eater, several 1960s-70's gas tractors with no Ethanol laced gas resulted damage..
I MUST be doing something wrong? :B
Well you’re about 100% wrong with it damaging small engines. 110% wrong on causing them to run hotter.
About 90% wrong on it making them run poorly....and yes I understand how octane and engine design work. And 100LL is only about 96 octane. Not a huge jump like race gas. Hence why it’s comparatively so cheap. Best part is it’s stable for a couple years, stored properly unlike any Normal pump gas.
Can’t speak to availability but here, I can pull up to the pump, pull a tail number out of my arse and it will dispense fuel. Even directly into my car or trucks fuel tank.
Save the lecture on that one for someone who cares.
Cost? No $2 gas here. Like I said compare to non ethanol + stabilizer it’s about a wash for a FAR better fuel. My money, my problem anyways.
And if your reading comprehension skills were astute, I actually said drain and run dry is the cheapest and best method.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
