dewey02
Mar 28, 2017Explorer II
clarkster wrote:dewey02 wrote:
We take our porta-bote almost all the time. You never know when you will come upon a good lake or river! 12 foot folding rowboat that attaches to the side of our travel trailer. Only 4 inches wide when folded.![]()
How do you mount the boat to the side of the camper?
This is a post I put in a different forum on how to put on the mounting brackets. There is more detail at that forum: Link here
I purchased a portabote and found there was very little information or examples of how folks actually mounted these things using the official portabote mounting brackets.
When I searched or asked on forums, many people suggested carrying it on the tow vehicle, or mounting on the roof of the tt or under the belly. None of those was really an option. The portabote site had instructions, but they were pretty sparce and didn't answer many questions.
After hearing back from several folks, I made the plunge and did the mount.
Since there may be others that have questions like I did, I've uploaded some photos that show the process I used to address problems like:
> *mounting to contour shape of the aluminum siding
> *how to keep aluminum siding from crushing when no stud in area.
> *how to spread the load over a wider area
> *how to keep my spouse happy about me drilling and cutting holes
> in her new travel trailer.
1st photo - front bracket showing plastic backer board cut to match contour of RV siding.
2nd photo - rear mount test fit (this was mounted through an existing stud and inside bolts were hidden from view under the sink cabinet.
3rd photo - front bracket did not hit a stud, so had to cut interior wall and insert a "cripple stud" to keep aluminum siding from crushing.
4th photo - used 3/4" oak boards to span between existing studs and to cover the cripple stud.
5th photo - the finished job!
Hope this helps
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
