j-d
Apr 17, 2018Explorer II
valhalla360 wrote:
Check all the ratings (not just GCWR) but if the 14,500 is the fully loaded weight that puts you at around 18,400 GCW pulling the mkz you well under the 22,000 GCWR.
On the surface, I'm not seeing where there should be any issue.
I don't see an issue either. But needless to say, the lighter the better, whether in what we pack inside or tow behind. We've had four toads in two pairs over the years. First was Toyota Tercel about 2200, Mitsubishi pickup about 2500. Traded for second pair which is Corolla about 2800, Nissan Frontier pickup around 3800. We could feel the weight differences in climbing grades and in stopping. When we got the Frontier, the plan was to use it as toad, didn't set the Corolla up with base plate etc. When we decided to try the Corolla we could tell at once that the 1000 pound savings made enough difference to make the equipping effort worthwhile. Now we don't take the Frontier unless we specifically need to have the truck.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
