WillT
Apr 17, 2018Explorer
carringb wrote:
You can't over work your engine or transmission. Worst case, if you're severely overloaded, a larger transmission cooler may be useful, but you won't hurt anything.
Keep in mind the V10 with the 6-speed TorqueShift is used in Medium Duty Trucks up to 37,000 gross combined.
I regularly run at 22,000 combined, sometimes as high as 25,000 combined, and I have over 450,000 miles and engine and transmission are original, except for some PM items (coils, injectors, timing chain, radiator) and my transmission is the old 4R100, which is not near as capable as the 6R140 that you have.
Thanks! This is really good to know. I am sometimes close to 17,000 combined. I did put the biggest transmission cooler on a while ago. I have worried a bit about pulling up long mountain passes. I know the V-10 does not mind high rpms but it does get loud once it gets anywhere over 3500. I tend to back off a bit to keep the rpms under that point but then I end up climbing the passes at 35 to 40 mph. I have the 3.73 gears and wish I had different, but mainly I think I just need to get used to letting it run at higher rpms when pulling up long passes.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
