rickhise's avatar
rickhise
How much clearance
Excuse my wording, Is there a minimum or acceptable
ground clearance between the bottom of the
Hitch an the ground , once your camper is secured on the ball.
rule of thumb. Thanks
  • Minimum ground clearance would be enough so that you don't drag the hitch anywhere you plan to go. For some, 4" is plenty. Others might need 12".
    I suspect that you are asking this question because whatever you are towing this travel trailer with sags pretty badly in the back when hitched up. Are you using a WD hitch? Is it adjusted properly?
    Hi, I can tell by the answers which are sort of all over the map, we do not understand your question. Please give us more info what you are asking with some specifics.
    You asked about "minimum" ground clearance between bottom of the "hitch" and the ground.
    If you mean a weight distribution hitch, we need to know the brand and type of hitch you have to give a better answer.
    If you happen to have a Reese, trunnion bar hitch with the dual cam, if you start getting much lower then 6" from the bottom of the cams to the ground, sooner or later you will touch the ground if a pot hole etc comes you way. 5" will hit often, 6" will usually only touch down if you drop in a hole.
    If you happen to have a round bar WD hitch, then the curved bars under the hitch head can be the bottoming out point. This also happens with a large drop shank regardless of the hitch. Again, 6" is around that same area. You go much lower and the bars can hit if the truck does a bounce and your transitioning from level to up hill on the truck at the same time.
    Also the truck suspension type and the loaded trailer tongue weight comes into this answer. A 1/2 ton truck with a 500# loaded TW camper will bounce lower then a 3/4 or 1 ton truck with a 500# loaded TW. So you can get away with a lower drag point on the heavier suspension truck if you have a lower TW in relation. But a 1,500# loaded TW camper on a 3/4 ton truck can be in the same problem as the 1/2 ton with a 500# TW. There is no one size fits all rule on this.
    These answers may be some of what you are talking about but may be way off base as we need more info on your setup and question. You where getting answers on ball height of the camper which did not seem to fit what your question was when you stated "hitch".
    Hope this helps
    John
  • Most trailers are around 20-21" unless it's a small utility trailer. When I upfit a truck at work that is the measurement to the top of the ball I go by when selecting a receiver.
  • I tow a Chevy Sonic behind and it requires a 4 in. drop to be level. Big problem with dragging the hitch.
  • Y-Guy wrote:
    rickhise are you taking about a truck/trailer or about hooking up a car to something? This forum is for cars being towed behind and RV. I can move your post to an appropriate forum I just want to make sure I understand your question.
    Referring to a travel trailer
  • If using a ball...I think 19" from the ground to the top of the ball is the standard.
    The important part, however is to keep things level.
  • 18" if you are asking about a bumper pull trailer
    Y-guy----
    OP has a Sportsman trailer
  • rickhise are you taking about a truck/trailer or about hooking up a car to something? This forum is for cars being towed behind and RV. I can move your post to an appropriate forum I just want to make sure I understand your question.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
