harold1946
Jun 13, 2013Explorer
Acei wrote:
Thanks for the responses. :)
When I mentioned 500w, it's not a single panel - say two 260w panels. I never looked at the roof view of a 5th wheel before though. How much panels can a typical 33ft 5th wheel handle on the roof?
I just read up a bit more on the solar panels. So it appears that there are 3 different types of panels - mono-crystal, poly-crystal, and amorphous. Unfortunately, none of them are best in all conditions so it will be either mono-crystal (for sunny days) or amorphous for cloudy/shady days. Is it possible to mix the two types of panels on the same roof?
I'm still not sure if I should go residential for the fridge, but we do expect to be off grid for perhaps 2 weeks at a time. So the solar panel might not be able to handle that if we end up with couple of rainy days in a row. If we are forced to get a Norcold 3-way fridge, how long does a can of 30lb propane last, assuming no furnace use?
I'm thinking of installing either 4 or 6 golf cart batteries.
You missed one type. Sanyo has a hybrid combining both mono-crystaline and amorphous. It is the latest in solar technology and the most efficient available, but they are not cheap.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
