harold1946
Jun 14, 2013Explorer
Acei:
You can mix/match panels if you are building amps as long as the voltage is the same and wired parallei.
You can mix/match panels if you are building voltage as long as you keep the amp rating the same and are wired in series.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
