Acei
Jun 14, 2013Explorer
wa8yxm wrote:
A good rule of thumb when figuring the output of a solar panel is wattage/2
If it's a 500 watt panel, then you might see more in say Arizona in August, but generally in the us if you get more than 250 consider yourself lucky.
So are you saying on a 500w panel, in the mid afternoon where the sun is directly above you, it will only generate 250w?
I've just read up on another article, and in that article, he says assume you can only collect sunlight around 1/6 of the available daytime hours - i.e. 4 hours. Does this mean for a 500w panel, it will only collect 2kwh on a typical day? This barely exceeds _ONE_ battery capacity (well, since I'm not allowed to drain more than 50%, I guess it's more accurate to say two batteries).
For those with experience, how much power does your panel collect per day on your configuration?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
