harold1946
Jun 14, 2013Explorer
Acei wrote:harold1946 wrote:
Acei:
You can mix/match panels if you are building amps as long as the voltage is the same and wired parallei.
You can mix/match panels if you are building voltage as long as you keep the amp rating the same and are wired in series.
I think this is a non-issue if I choose to go with the Sanyo/Panasonic HIT series panels. I'm not sure how many panels I can fit on the roof, but I could look into fitting 3 x 240w panels.
Just answering what you had asked previously.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
