Acei
Jun 14, 2013Explorer
KJINTF wrote:
For us the current supplied by our 550 watt PV array has on many occasions produced 40amps (the full 550 rated wattage, Battery voltage sitting at 13.6 )to the loads. Every once in a while 43 amps ( A bit more than the rated wattage) as seen on the TS-RM-2 is being produced by the array. That said we live in a cool climate, hot panels drop in efficiency quite a bit (Arizona in August = VERY HOT). The above is during the middle of the day with cool weather and direct sunshine while I am loading the system with the on board 12 Volt powered compressed air system.
One of the reason for going full-time is to avoid extreme temperatures, so I doubt we will face really hot temperatures. During the winter, we will be in southern states, and during the summer we will be in Ontario, but probably up in the north side. It might still get hot here but not Arizona-hot.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
